Grandpa Mike
- Joined
- Mar 11, 2013
- 39
My son and I are resurrecting and oldie and I have some concerns about the engine cooling. I was browsing the forum and came upon reply from HighTrim re: another cooling system issue about water output.
He suggested to the OP that his motor may have blown an impeller and blowing out the cooling circuit would be a good idea. Sounds like good advice to me but I have a few questions.
In my other threads and postings, I've explained how my son and I are going through this engine thoroughly. More or less, new everything. Complete ignition system, carb overhaul, lower unit and w/pump housing & impeller. We're coming to the home stretch now and nearly ready to reassemble and fire it up. (it ran in the first place, badly...but it ran).
I could really use a diagram or detailed description of the cooling system circuit. When we first started it before the overhaul, we got fairly good output from the w/pump but the choke would not unload and the engine got too hot IMO. Water would sizzle on the head and was really too hot to hold my hand in the stream.
Yesterday when I removed and disassembled the carburetor, I noticed that the water jacket on the choke was bone dry on the inside and there was no water, or trace, present in any of the engine water water hoses.
Yeah, more than likely there are either chunks of an old impeller, barnacles, chicken bones or some other lake debris clogging a water passage somewhere. We also included a new thermostat in the rebuild goodie box. Marine engines are not my forte and I could really use some info on the routing of the cooling circuit.
Thanks everyone.
Mike.
Thanks everyone.
Mike.
