Re: I need to remove rear cover latch on 9.9 Evinrude
It's been awhile but I assume the problem is there isn't enough room to remove the hex bolt from the latch, right? Simply pull the latch handle out of the hole at the same time as you unscrew the bolt. Reassembly takes a bit of fiddleing but can be done.
