MotorheadTed
- Joined
- May 2, 2011
- 50
I recently bought a very clean 1992 Sportcraft 232 wac with a V/P 431b eng and DP-c drive that was a freshwater (Lake Erie) boat until two years ago when the p.o. brought it to florida, used it in saltwater a few times , then parked it. It still had the original volvo exh manifolds one it, and the engine is in remarkable condition, with the original carb still bearing its original paint on including the screw heads !! Low time boat for sure !
Problem is the out drive has an unusual amount and type of corrosion . The skeg has the worst corrosion which goes about a third of the way up, then stops at a definite line, as though it sat in the water with the drive up with the skeg partly in the water. The main body of the drive is fairly corrosion free, but the separate mounting/swivel piece is heavily corroded, especially around the mounting and trim ram pin holes.
I question the bonding of all this. Anybody have any experience/thoughts about how the drive should be bonded ?
TIA,
Ted
p.s. I'll try to post some pics later
TIA,
Ted
