2007 Southbay Trifecta with an I/O. I have been finding in rough water I am getting an inordinate amount of water in the bilge. Enough so that the stock 500gpm pump which is not working at its best (I think the impeller is bad, pumps for a bit then still turns but stops pumping have to give it a shake to get it to pump some more) so I replaced it with an 1100gpm one that keeps up no problem. It only does this when in rough water. I have gone over the hull with a fine tooth comb and can find no holes or cracks that would cause this. What I did find was from the engine bay toon and the two outside toons they used some kind of a grey caulking or sealer that is spread about an inch wide up to 40% forward of the rear then it is just the splash plates stacked one over lapping the other. The only thing I can figure out is maybe the water when rough since there is more toon in the water forward due to the wave peaks maybe the water is getting in there and traveling along the under penning to the bilge. Anyone else have this issue? Solutions?
Thanks
Scott
Thanks
Scott
