The short answer is . . . Water does not siphon uphill . . . I'd worry about something else, unless you have a leak to attend to.
Given that there is engine plumbing below the waterline, is it possible for water to siphion from the out drive into the boat, while at rest, due to leaks or mechanical faults?
or up the leg from the exhaust and do the same, and only through a high/low siphon action, boat at rest engine off. I do see where the risers protect the valves.
