Re: I/O versis outboard & inboard fuel efficiency
Each boat has its own characteristics, so it really depends on the type and brand of boat. The weight and hull are very important factors. As an example, a boat that weighs 3,000 lbs vs. a boat that weighs 6,000 could use half the horsepower.<br /><br />It looks like you want everything.....best speed, best fuel economy, and best ease of maintenance. It's hard to get everything, but I'm sure there is a best combination. Usually the boat manufacturers set the boat up using the best combination for its specific use.<br /><br />With that said, it's my opinion that the inboard and the inboard/outboard would perform about the same. If the inboard boat was a "keel" type, then it would be slower and require yearly maintenance of the propeller shaft. The I/O would probably be a little faster, but require more maintenance of the outdrive. Fuel consumption difference between the two would be close and would probably come down to prop. Again in my opinion, the outboards would be less costly to maintain. But you inquired about 2-strokes, not 4-strokes, so fuel economy would probably be worse witht he 2-strokes. Not with the 4-strokes.<br /><br />Horsepower is horsepower, whether its inboard, outboard or inboard/outboard.
