Re: I/O winterize Ideas and opinions
OK, after everyone has given their opinion here is my take and why.<br /><br />First I'll bring the engine up to operating temperature using muff on the garden hose.<br /><br />Then,<br /><br />with four 4' 2x4's (cost 1.79) I'm going to lay a piece of 10 mil plastic (Cost free)over the board allowing it to settle comfortably within the board onto the ground.<br /><br />I'm then going to set my small portable sump pump in the middle and fill with about 3 or 4 gallons of AutoMotive 50/50 antifreeze. I'll connect the sump pump using 3 foot garden hose. (Cost 3.00, chopping off section of hose)<br /><br />I'll plug in the pump and start the engine, and allow the antifreeze to circulate through the engine...Since only 4 gallons of Antifreeze mixture is available it will likely become hot if circulated too long, (Trips through the engine)..<br /><br />Here's why..<br /><br />1. Using the pump, I eliminate the concern about gravity feed system, and possible overheat or running dry.<br /><br />2. Environmentally, I'm recapturing the antifreeze mixture for use next year or on my other boat. When done simply pump mixture back into my 4 1 gallon containers.<br /><br />3. Low cost, I already own everything I need.<br /><br />4. All of the caveats associated with the 5 gallon kit setting on the swim platform seem to be filled with warnings, gotcha's, valves, prefills, etc, and where does the mixture fall, onto mother earth unless you capture it in a container somehow, why not just pump it from this container in the first place...And that's what I'm sticking with...<br /><br />Of course I will follow all of the other steps to winterize by draining the block, hoses, fogging, changing oil, etc. But the basic benefit of doing this is easy, affective, complete.
