cheaperts
- Joined
- Feb 12, 2012
- 55
1981 470, been running great, cooling great, just did alt conversion, all is well. Couple of evenings back I was out flinging teenagers off the tube, running pretty hard. Temp gauge (new this year, probe is in the exhaust manifold) never showed above 180-185. The old boat has idiot lights in the dash, I assumed they don't work, well low and behold I go to restart the boat after a tube run and the the temp light is glaring at me! Gauge was ok, 180, but the light was a glowing, then went off after 10-15 seconds. I'm guessing where ever the sender for the light is, climbs up some right after you shut down and then cools right off once it's running and flowing again. Only happened after short shut downs to swap out riders and went right out once the engine was running again. Not a problem, right? And what is the magic temp that should make me worry, 190? 200?
