tcfarmer
- Joined
- Jun 3, 2008
- 9
I own a 1985 Evinrude 115 with VRO. I recently took apart the fuel/oil pump to investigate my lack of fuel to the carbs. When I took apart the pump I noticed the small black rubber ring was concave and not flush against the plastic piece behind it. So I flipped it over and BOOM! I cranked it and I had fuel come out the top of the pump. Currently my only issue is when I am on the lake it Idles and runs perfect but when I jump on it full throttle it runs just long enough to get on a plane and just start to get cookin then it starts acting like I am out of gas. I had 2 thoughts on this either there was some kind of restriction in the brand new fuel line or in the tank so I removed the fuel gauge sending unit and dropped the hose directly into the tank and ran it on the trailer and with in 1-2 minutes it started coughing and then it died. If I let off the throttle and run at 3000rpms I can cruise all day but as soon as I go wide open it nosedives. I noticed on the fuel pump it looks like the diaphragm is adjustable to I put a couple turns on it to try to get a longer throw on the diaphragm and it didn?t make any difference. If any one has any thoughts I would surely appreciate them as I am at my wits end and I cannot afford a new fuel pump assy, at least not for a while. I was looking online and saw a rebuild kit I wonder if thats what I need?
