aggiedave98
- Joined
- Jul 14, 2003
- 231
Yesterday, I had my 2004 Starcraft Stardeck with the 5.0L carbed V8 out. We were out for several hours and everything was fine. On the way back to the dock, I turned it off to bring my daughter in off the tube. I tried to start it and it would turn over once, then nothing. I tried that a few times and thought I had a low cranking amps on the battery, even though it was at 12.4V. A tow driver came over and we tried to jump it. I tried it several more times, thinking it just didn't charge up enough. The last time I tried it, it made a strange sound like something snapped maybe???
I read up on hydrolock and think that has the symptoms maybe???
Do you guys agree and if so, what should I do now? Should I try taking the plugs out and turning it over or could I do more damage if a piston got bent?
Thanks.
boat serial: 78733c404
reverse drive
outdrive
TSK-SM-M
3868844
serial #4151056372
engine 5.0GL-E
3869254
serial #4012 1205 94
Thanks.
reverse drive
outdrive
TSK-SM-M
3868844
serial #4151056372
engine 5.0GL-E
3869254
