agaldamez
- Joined
- Mar 31, 2013
- 55
i have a 4.3 mercruiser, this year i had a tune up done on the engine the mechanic told me all the spark plugs had rust on them.so he did a tune up and it was starting wonderful. i wonder at that point should he have said something about checking the manifolds?
Now as the summer has gone by it is starting to not turn over every time I try to start it. I will turn the key back and forth then it will finally crank, sometimes its a slow crank.
I purchased the boat used and I have had it for over a year.
I did change out the thermostat because my temperature would never go above 120 degrees. now that i have done that, when i go at high rpm's I am getting to 180 degrees.
I am going to remove spark plugs to see if they have moisture or rust again. If I do, I plan on changing the manifold and the elbows.
Any advice, should i pay someone to do it, should I stick with mercruiser parts. how do i know how much damage has been done to the motor if the manifolds and elbows are leaking.
The engine otherwise seems to be running great.
Any and all suggestions would be appreciative.
thanks
thanks
