Re: I Think I've Got Another Blown Reg / Rec
Thanks for the tip WillyBWrite. I forgot to mention it?s an 86 90hp VRO with VRO disabled and 10amp Reg / Rec. The problem was a temp alarm.
This past spring when this happened I replaced the water pump, cleaned the scale from the water jacket around the cylinders, and the heads, and inside the block where the Reg / Rec mounts, repositioned the water jacket diverters, replaced the thermostats and pop off seats, and last (the thing that stopped the temp alarms) replaced the Reg / Rec.
I took it out yesterday afternoon and ran it for about an hour with no problem. I wired a 40 amp automotive amp meter into the system the way the OMC book says to and the Reg / Rec worked as expected showing a peak of around 7 amps at 4500 rpm then dropping off as the battery charged. I also brought a temp reading multi meter with me and it showed the engine running at around 120 deg. All perfectly normal so maybe it was a false alarm.
