ok so let me start off my saying this. i have a 1988 sunchaser 3.0 mercruiser with alpha 1 out drive. it was one of the craigs lists deals. i bought the bopat for a grand. the interror is in very good shape and the floor had been replaced. i have gone through and fixed most of the small issues that an older boat can get. when i bought the boat i was informed that iit had a cracked block. i figured that i could try the glue back together bethod, that did hold for running on the muffs. now when i run it on the water at w o t i am only getting just shy of 4000 rpm. and the bildge area fills up with water in about 15 min. kick the bildge on and in no time it pumps that out.
i am mechanically enclined and i could change the motor out myself and was wondering what my options are? do i go back to a 3.0? if so do i find a new or rebuilt? or what about finding a new block and put all of these parts in it? now the back of this boat has plenty of room to support a v8 and that would be sweet. other then changing the motor mounts, the exhaust, and that kins od stuff can i put a v8 up against an alapha 1? if so can i use an auto block and slightly build up a 5.0/5.7 as long as i run a marine cam? or does any one have any other suggestions??
we really do enjoy being out on the water and dont want to toss the boat to the side i would much rather fix what we have insted of starting over. and once again many thanks in advance
