89 evinrude 40hp o/b<br />BUT, i need to ask a few ?... 1st the tune up sequence has me starting with a comp test OK thats suppose to be easy right? i bought a very nice high end tester that we'll be working with.<br />so here goes.<br /> CAN THIS TEST BE DONE WITH MUFFS??? <br /><br /> warm engine FOR HOW LONG???<br /> remove plugs and wires ground 1st wire to block connect gage to hole that 1st wire goes to. DO I GR. 2ND WIRE WHEN TESTING 2ND HOLE OR CAN I CHECK BOTH HOLES GROUNDING THE SAME WIRE??? <br /><br />now i need to make sure the throttle's held wide open. HOW DO I DO THIS???<br />from the control box or right from the engine.<br /><br />now if i'm using the muffs this is were i turn them back on and crank the engine over at least 4 compression strokes. RIGHT???<br /><br />HOW DO I TURN THE ENGINE OVER??? sense i've disabled the ignition system.<br />i have a remote starter but need to know how to hook it up before useing it.
