I want to Reupholster
Plainsman
I want to try my hand at reupholstering the seats on the boat. Does anyone have a link to get the upholstery material? Also the foam.
Thanks,
Eric
Bob_VT
Re: I want to Reupholster
Google marine grade vinyl or check ebay. Remember to use Stainless Steel Staples.
tashasdaddy
i've found excellant quaility & price at Jewett City Upolstery, dsarasen@sbcglobal.net. i've order from them several times, and very satisfied.
Tail_Gunner
http://www.perfectfit.com/about.asp
They are a complete one stop shopping for upholstry and great pricing.......... Ask them about there Trade Win's line great stuff and very inexpensive. Currently i am in the middle of a job and using the pearl, It is a pearl essence that is absoulty gourgeous..... good luck
Cptkid570
Ensign
The foam is more expensive than you'll think. If possible, try to use your existing foam.
I've bought vinyl off of ebay and was very happy with the price.
Bass-A-Holic
As far as tools go i think you would want an air staple gun (which u may already have been talking about but wanted to be sure;)) and a hair dryer may do the job but a heat gun will be much more effecient. you may need more tools also but when i helped reuphlster in my dads car thats all we needed
Tail_Gunner
Agreed here, im half done with a old 93 Starcraft and the foam was just fine, however it had been compacted over the years making for a bad fit if you use the old pattern to make your new one.
What i did was to steam the foam with a iron which brought it back to it's orignial size and shape.
Here you can see the ridges left in the foam from the old design, if you do not steam them out they will show in your new vinyl. I simply saturated the foam with water and used the iron on high heat to steam out the all the old imprint's and it expanded quite a bit to.
Here ive done the left side of the panel and you can see how it takes all the deformities out and increase's it's size.
Before again
After
And back on.
Plainsman
Well I finally got the upholstry and am having a hard time figuring out how to fold it aroung the corners. I don't like the "folded" corner look.
How do I make the corners look "smoother"?
Silvertip
You've got way too much material at the corners. Take more and smaller folds. Always a good ideal to take pictures of the old material before it was removed so you can see how it was done. It may have been sewn at the corners as well. With a thick seat, try starting in the middle of the corner. Pull the material (one or two fingers width) down and pop one staple in. Going one way or the other from the center, make a small fold (again, one or two fingers wide) and pull it tight. Repeat on the other side always working away from the center of the corner. Don't be afraid to ruin a cover. You are learning and the material will not break the bank. Before you go any farther, why not stop at the library and look at some "How To" upholstery books. A picture is worth a thousand words.
aerwin
to not get the folded corners you have to sew the sides and front onto the seat piece. I did the same , I had a little knowledge of using a machine and I just took the existing seats and cut them apart and made new pieces and sewd them together. I didn't use marine grade vinyl, just the vinyl that wal-mart sells, I was on a really small budget. I looked at alot of seats and figured out how to make the seams. three passes to get a seem. it looks pretty good for the first time. I didn't have a good machine and that will make a huge difference
bruceb58
Here is a good book you can get and a good forum to get info from:
http://www.amazon.com/Automotive-Up..._bbs_sr_1/002-3445691-9578406?ie=UTF8&s=books
http://www.get-up-and-go.com/upholstery-forum/index.php?board=1
Aerwin is correct...you have to sew panels on the side of the cushion to the top of the cushion before you can staple it to the bottom. However, you really don't want to do multiple passes to creat the seam...less needle holes=stronger seam.
Another suggestion...air stapler will work the best along with stainless steel staples.
iwombat
Cut pieces and pin 'em in place inside out leaving a little bit of slack. Remove the piece and sew up where you pinned. Turn it right side out and staple in place.
kenmyfam
After seeing this I will take mine to a pro and to hell with the expense. Mechanically I will tackle anything but that looks like a nightmare if I attempted it !!!
bruceb58
That was a pretty bad example of how to reupholster something. It would be the equivalent of taking a piece of fabric, cutting a hole in it and calling it a shirt.
kenmyfam
Thanks for the info. Maybe I will try something small that does not matter if it goes wrong !! before anything on the boat. I am a good few years from re-upholstering but will bear this in mind.
bruceb58
You know what...the only way you are going to learn is to try.
I would start on a small flat piece like the picture above.
Not like working on your sterndrive where the consequences of messing up are magnitudes higher.
Good luck!
iwombat
The inside-out pinning technique is pretty foolproof for fitting vinyl to your form. It only gets hard when you want to put piping on the seams and the like. Give it a shot, you'll be surprised.
And what's wrong with my square hole-in-the-middle shirts? Huh?
