Hi guys,
I've been reading a lot of posts about aluminum boat hull painting, but now it's finally time for mine to get started and it seems like all of the different methods I've read about are too much to sort through.
What I'm looking for is an inexpensive and easy hull finish that protects the aluminum from the salt water & corrosion.
The end-result does not need to be perfect in as far as finish, so if I have to sand, I want to sand one time only just to get the primer to adhere.
I don't know much, but I think I've read to use TSP to clean the hull and to etch it - I don't know if that will clean up the white spots and take the oxidized paint away, or if I need to lightly sand all areas first?
My plan that need filled in is something like:
1.) finish taking off the deals
2.) use ___ to take off decal residue (I just bought acetone, so if it would work I will be ahead of the game)
3.) removing the remaining transom hardware (the two sensors and I guess that PVC-pipe looking nut that is for the livewell - I hope it's a standard sized PVC)
4.) (?) lightly sand most everything with __?__ grit
or can I
5.) wash down everything with TSP and scrub it all with a green scotchbrite pad (instead of sanding? or after sanding?)
6. wipe dry
All coatings will go on with a Roll and Tip method unless some other easy method is suggested - I will not be spraying.
7.) (?) ALUMAPROTECT , or some other chromate pre-treat? What is cheap here that works?
8. use a high-build epoxy primer that is safe for aluminum, Perhaps some Interlux product by the gallon (I imagine one or two gallons will be enough). This is the step which I am willing to spend the extra on epoxy for a strong and good finish.
9.) lightly sand epoxy primer?
10.) paint with some inexpensive glossy white paint that will hold up to salt water for a while (suggestions? I'm looking for a smooth finish)
Pictures:
white spots:
oxidation of paint:
high spots:
I don't know if these will fill in more with high-build epoxy primer?
one crack in a bottom - runner - thing:
Not too worried about the crack, but I can have it welded (costly), epoxy it, fill it with something or leave it alone
back of boat:
Is this regular PVC?
Probably should have pulled this apart before flipping it, but I'll take it apart now. My concern is that, being from 1985, it may not be some standard PVC nut or size pipe to replace.
Thanks!
or can I
6. wipe dry
Pictures:
white spots:
oxidation of paint:
high spots:
back of boat:
Thanks!
