identify 115
tblshur
i have a motor with 82 johnson 140 power head noticed the bracket model # 115etl78c cannot find that model # no where what am i missing thanks for any help:joyous:
F_R
115ETL78 is a 1978 115hp. I don't know how it got to be 140hp or 1982.
Agreed----A 1982 powerhead was installed.-------Is there an issue with powerhead or the lower unit on your motor ?
tblshur
yes you are right the guy i bought it from didnt mention the 140 82 had a 115 78 lower i changed the impeller on my 83 140 it was in good shape so ithought i would put it in the 82 140 lower well that one had a woodruff key instead of the flat one so now i started checking and low and behold it leg tag says 115etl78c .i wanted to put it on my 83 run it a bit see if it is ok will that be ok or cause problems thank you all for your help
