kaupinator
- Joined
- Jun 21, 2010
- 20
Hi all, I need help identifying and old Eska I pulled out of the garbage. I finally found a tag that was covered in paint. After removing the paint I found it was an Eska tag with model # and serial number. The model # is really faded but I believe the last numbers are 1142. It looks like there is a space for about two more numbers in front of the 1142 but it is impossible to tell if there is something there. The serial number is 22752. I have found some info on a model # 1142 but I can't find anything at all about the serial number. I have been told that it is a 3.5hp eska and I have been told that it is a 5hp eska. The lower unit does not have neutral. The lower unit has a curled tube down by the propeller that looks like it was designed to have water forced up it by the movement of the prop. I started to pull the lower unit apart to see if it has a water pump but the curled tube will not let me drop it. I suppose it is attached up in the leg somewhere. Any info about this motor will be great. I already know about the fuel pump element being a problem and mine was in pieces. I did get it to run for a few seconds so I would like to save this old motor.
