Identify this part game
Jim Hawkins
I found this thingy lurking in the lower engine cover wedged under the motor while cleaning. Surely this is the part that if I know where it goes then reinstalling it will make my motor run like new, increase gas mileage and make my investments skyrocket! If I only knew what it was...
Seriously, I don't even think it's part of the motor but I would like to know what it is or what it does. The one end looks like your typical valve stem for a tire. In the middle is a rubber O ring.
Name that part !
Jim Hawkins
No Title
Its part of the cap fro the primer solenoid
Jakedaawg,
The parts diagram shows that part as just a lever without the valve and cap on the end. Whats the use for the valve? I'm thinking I should order one without to replace it.
jakedaawg
A brp fooging oil can hooks to it for winterizing. Anyway, thats what it is. Later primer solenoids had the schrader valvenasnpart of the red lever. Earlier models had just a lever.
Jim Hawkins
Any chance I can glue it back in? If I try to put it back in, it's tight and probably wont come out, that is, it probably wont come out until I'm out on the ocean or something.
jakedaawg
Just buy a new cap assy. 20$ or less. Couple screws. Easy and done.
