Identifying Johnson Motor
slvrgbln
I bought a boat several years ago. The motor is I am guessing is a 78. I was told to get the #s off the welch pin. I did, but it does not follow the logic I have seen to identify the motor. The #s are 6R78B J4914924. Somebody stole the hood cowl and I am trying to replace it. If you know the what the motor is (hp & Yr), do you also know what hood cowls will fit it? I still take my kiddo fishing, but it is louder than heck. Any help will be greatly appreciated!
cougar1985
Re: Identifying Johnson Motor
by inputting the numbers you gave (6r78b)brp site comes up with the following ,1978 6 hp. johnson. you should be able to find a cowl at a salvage yard or maybe at a marie dealer or even ebay.
tashasdaddy
call the number at tcoutboard.com
rktdude
I've got a Jhonson sea horse modle # v4512s what year is it
stman5150
I recently boat a small boat with a Johnson 18hp sea horse on it. I would like some help determining the age of this motor. The model #FD-15F, THE SERIAL #2215495
Joe Reeves
Model V4512S is not a OMC model number. However, model number V4S-12S is a 1960 75hp Johnson. You're mistaking the first "S" for a "5".
FD-15 is a 1961 18hp Johnson
wwcaseyjones
i have a simular question. i bought a 76 sea star tri hull recently. it has a 55 horse johnson but the id plate on the bracket has been knocked off. is there somewhere else the numbers would be? any help is appriciated.
ezeke
Model numbers are sometimes found on the serial number plate on the engine block. It will be a nickel-sized convex aluminum plate a/k/a welch plug.
