Idiot removed shift pivot screw, HELP!
schneldb
I'm the idiot. It's an 88 Force 125 OB. I read the book wrong, thinking I was pulling the drain for my lower unit so I could change the impeller. I instead pulled the pivot screw that connects the shift linkage. Is there anything I can do to fix this without tearing the whole unit apart? Thanks in advance.
stinger1
Re: Idiot removed shift pivot screw, HELP!
sorry <br />i wont be much help, cause im new and not a mechanic.<br />but post this in the boat engine forum and they will surely be able to tell you.<br />those guys great.<br /><br />they will see it here to though<br />i think they surf the whole site
ODDD1
Schneld, I cant give you good news...almost certain the case will have to come off to repair....but when its done FILL THE POCKET THE SCREW GOES IN WITH SILICONE! it wont happen again....
fishthebay
I did the same thing on my 87 85HP force last year. Fortuatly, I was able to put the screw back in without having to have the unit broken down. I took it to a mechanic to check out and everything was fine.<br /><br />Try to put it back in and see what happens.
schneldb
I fixed it. I had to tear it down to the point that a shop would have to go farther from there. At that point I could see everything that came apart. Thanks to mechanical fingers and a lot of patience I got it all together again. I was really freaking out because I was taking it to a lake for Labor Day weekend. We made it, and the boat couldn't have performed better. If anybody has this problem please contact me, I can give advice in detail what I did to fix it. Thanks for the replies I received.
intrigueing
Schneldb, I know your post was long ago, but any info you have on the repair would be appreciated, I just got a boat that has the pin missing.
cpasseno03
Both drain plugs are flat head! I learned that the hard way also... The phillips one is the pivot for the shift fork, that slides one gear into either one or another (forward or revers) Take the screw out, and remove the lower portion of the gearbox (it splits along the centerline of the prop shaft) When it comes apart (carefully) you will see how everything works, it is rather simple. Line it back up and reassemble. When pulling off the bottom half of gearbox, go slowly, and try to line it up without taking it all the way off, that helps me sometimes.<br />And sometimes its already lined up and you can just reinsert the screw, but when are we that lucky?<br />Craig
moderator1
Moving to Chrysler/Force questions.
