I have a 93 Evinrude 50 Hsp that I am needing some advice on idle adjustment. I bought the boat a year and a half ago and the owner had just had the pistons replaced. The mechanic that worked on it said it needed 3 tanks (18 gallons) run through it at double oil to break in the motor. (It has the VRO so I was mixing 50:1 in the tank also.)
Last year, I just ran the last tank of double oil dry before putting the boat up for the winter. All season, I had trouble keeping the boat idling. It wouldn't idle without dying most of the time. I attributed that to the double oil causing the problem so I left it alone. As I recall, the tach said around 600-700 at idle. (But I could be mistaken.... I'm over 40 so the CRS is kickin in.)
After pulling the boat out this spring, I realized that the plugs that were in it were the wrong ones. It had QL78C plugs and the motor calls for QL78YC. I don't know if that makes much difference or not. (Not sure what the extra Y means) I replaced them with new QL78YCs gapped at .030.
I also decided to replace the fuel filter and notices it had the wrong one in it. It had part 398327 in it which has 5/16 nipples on each end. The motor called for part 435918 which has a 5/16 nipple on the supply side and a 3/8 on the delivery side. Also, the direction arrow was going in the opposite direction of the fuel flow so it was installed backwards. (However I don't know if that matters that much ... I blew on it from each end and couldn't tell any difference in restriction.)
After a few cranks to get the gas flowing, it started. The motor seemed to run less sluggish at idle than last year and it doesn't die. (At least on muffs in the driveway) In fact, I think is idling too fast. The tach shows about 1500 at idle. I'm not sure what the recommended idle speed is, but it sounds a little too fast to me.
My question.... I've heard that idle speed on muffs is different than while on the lake. Is there a rule of thumb to set it on muffs so that it will adjust accordingly at the lake? What are the recommended rpms on the water and on muffs?
I thought I probably shouldn't mess with it until I at least try it on the lake but if the experts around here have some standard rules of thumb that work, I might go ahead and try it.
Also... I assume I only need to adjust the idle screw which I think is located on the side of the motor and has a bolt with a rubber tip on the end along with a nut to lock down the bolt once adjusted. Is this correct?
(See red arrow in photo) Thanks for your help.
