idle adjustment question?
sparky71
Hello,
I have a 19' Baja 190tc with merc.MCM260 #6356454 carb #'s are MCM 260/270 1347-8292.I believe this is the q-jet correct?
I'm running about 1000 rpms which seems high.I've benn trying to find links here for adjusment procedures but am not having any luck.Is 1000 too high?and if so what should it be?
hullofalottatrouble
Re: idle adjustment question?
yes way too high.. there should be an idle speed screw on the side that you can adjust to bring the idle rpms down.. get yourself and OEM manual.. its got everything you need to know
sparky71
Thats what I thought so I figure 700-800 sound good?
sparky71
oh yeah any links? And how do I put my boat info in at the bottom of the post...or do I have to type it in every time. Thanks
Wotknot
Click on "user cp" up near the top of the page..........then click on "edit signature"
hullofalottatrouble
if you have a 260 you want 650-700 in forward gear..
its best to get a digital multimeter with RPM reading on it as your dash gauge will not be nearly as accurate.. can get them at auto parts store for like $40..
