hoeser
- Joined
- Jun 18, 2006
- 253
You may have seen my posts relating to the recent rebuild of my 1984 Evinrude 140 Crossflow v4. One of the rings let go due to carbon buildup. The more I read about carbon buildup the more I am concerned about my WOT RPM. Pre-rebuild we could get the engine around 5400-5500 with two people in the boat. It is on a 1970 Searay SRV190. With 4 or more people in the boat it was more like 5200-5300rpm.
I am not sure of the prop specs. Is this high enough or should I be closer to 6000rpm wide open? I have not run WOT yet post rebuild.
Hypothetically speaking if you were making a 30 minute trip across open water... would you build up more carbon at wide open than say, 75% throttle? I'm confused. I always thought I was being "easier" on the engine running it at 75% but it sounds like I may be doing more damage that way.
