Ok first let me give you some background the motor is a 1976 evinrude 115 hp. Motor idled fine when I put the boat away in November. On Monday I replaced the cable to the engine, they were older and sticky so I replaced them. That went fine, took it out that day for a test run. Noticed that it would not continue to run at idle I did notice that if I pushed up the warm up lever it would stay running. Then today I took the boat back out and noticed that the motor will stay idling if the cover is off. I put the cover on and with in a few seconds the motor idles down some and then a about 20 secs. later the motor dies. I talked to a shop today and they said it might be one of the exhaust seal. But what gets me is if it is that why would the warm up lever keep it running if the exhaust seal was bad. Also the motor runs great once its not idling.
