Idle Button on 175 evinrude saltwater edition
cionjay
I am trying to figure out what could be the problem. when i put the motor in gear it will not turn the prop. I was wondering if this motor has an electronic idle mech that can be stuck. because on the controls there is a button that can be pressed and you can then move the controls foward to rev up the engine when it is cold. if there is such a thing how would i check this or bypass this feature. (it does the same in reverse).
thanks,
F_R
Re: Idle Button on 175 evinrude saltwater edition
Does the shift cable move back at the motor? It could be broken. Or the control could be broken.
