mikelam123
- Joined
- Jul 20, 2009
- 3
Ok so here we go it may be an easy fix for some of you guys my motor will idle perfect as long as it is on muffs with the water hose but just as soon as it gets in the water it will not idle if you get it to idle long enough to get it into gear it will run fine as long as you want to go but as soon as you put it into neutral it dies and will not start back without starter fluid HELP!!!!
