I tried to set the idle mixture screw on my 1998 75 ph Force. Only one carbie so it should be easy.
I set the screw to 1 1/8 turns out, boat in the water, in neutral about 1000rpm. The engine ran OK. ? turn in the motor ran rough. All good. When I turn the screw out past 1 1/8 it didn’t seen to make a lot of difference. I stopped at about 2 3/4. The engine ran slightly rougher but not much. I have been running the engine with the screw at about 2 turns out for the couple of hours as I had this trouble when I serviced it. Tried to set it again last night but had the same problem.
A bit of history. The fuel is about 10 weeks old (no E10). I have just finished servicing it. Timed, new plugs, new fuel lines, new inline filter and water separator, new wiring loom, removed carbie and cleaned. I posted some photos of my plugs on another thread and fucawi thought I may be getting some water into the motor. I still need to check this although I would have thought it would make the engine run even rougher.
Latest photo of plugs after about 3 hours of running. A fair amount of time at idle looking at the sounder and trolling.
Is this normal or should I try to clean the carbie again.
Thanks
Dean
Left to right, cylinders 1 to 3
Thanks
Dean
