steviecops
- Joined
- Oct 3, 2003
- 585
I have just stripped down the carbs on my 1980 Johnson 55 to clean and rebuild.<br /><br />In my manual, it says the pre 1980 engines were fitted with 0.045 idle orifice jets, but that these engines had a bad idle. So, the 1980 on engines were fitted with a 0.046 jet, which improved the idle. Carbs with these bigger jets had a letter E stamped after the number on the carb.<br /><br />My carbs don't have a letter E stamped on them, and when I took the idle orifice jets out to clean them, I noticed that they had the number 48 stamped on them. Does this mean that the size of the jet is 0.048? If so, should I leave them in, or replace them with 0.046 jets?<br /><br />Thanks in advance.<br /><br />Steve
