Hi People! I have a 1978 IL6 1150. I finally got all the electrical issues worked out and put the boat (16' Avenger) in the water for the first time yesterday. Wow!! The engine started great and screamed at WOT. It was was way faster than I had imagined, and ran beautifully.<br /><br />The problem I did have was at the dock. At idle, the engine is barely running and when I gently slide it in gear, it dies. If I jam the throttle from neutral into gear, it takes off. Idle while in gear is good too. I think the idle just needs to be turned up a little, but I don't have a repair manual yet, and even if I did I'd be scared to mess with those carbs (yikes!). Is there a way to up the idle a little without adjusting the carbs? Can I adjust it with the cables somehow? Also, it starts and runs great using the fast idle. The contoller I have doesn't have a seperate fast idle lever by the way. It is integrated into the shifter with a little button.
