pursuit2460
- Joined
- Aug 24, 2004
- 189
Well i took the boat out today and I having a little problem with the idle. When i shift it into gear and start to give it gas it dies out, it also dies on idle when not in gear. it sneezes and coughs on idle. I went and checked the primer bulb and is was soft very soft like all the fuel had gotten sucked out. So I primed the bulb and then shifted into gear it took of but with some little hesitation. Could it be that i have a bad fuel pump. thanks
