Idle problem
baycruiser
I have a 1995 350 Mercruiser with a alpha one outdrive in a Donzi Classic 18. Runs great Wide open but does'nt want to idle after warming up. Just installed new feul pump [manual], ignition sensor, and coil. Also new cap, button, and plugs about 20 hours ago. Can't figure it out.
Don S
Re: Idle problem
Is the choke operating properly?
baycruiser
Re: Idle problem
Choke plate opens fully when up to temp. Found after idleing a couple of minutes it chokes out and fuel ls leaking from right jet into carb for a few of seconds.
Re: Idle problem
Ayuh,... Time to Rebuild the carb...
