astuckey
- Joined
- Sep 4, 2011
- 83
Hi, I have a 1988 Gm 4.3l. that I just rebuilt the carb on. I rebuilt it because the acceleration was bad, and we weren't getting very high RPMs. Anyway, since I put the carb back on, I have had the following problems. At first, it took some time to start, but after a few days, that problem seemed to go away. The other problem I am having, is bad idle, primaraly when cold. Regardless of choke position, when the engine is cold, it will idle slowly, and slightly rough. (around 400 RPM) Also, it is not overly responsive when in this cold slow idle. If I move the throtle to get it to anywhere over 600, it runs perfectly! Both idle screws are set to 2 turns out, which seemes to work the best, and was recommended by the rebuild kit. I would just adjust the idle screw on the throttle, however, it idles at a smooth 600 when warm. (And when I say warm, I mean anywhere above about 145) Any help would be greatly appreciated!
Thanks
Thanks
