I have a 98 yamaha 115 hp and it is currently idling at 1000-1050 out of gear and between 700-800 in gear. My question is ... can the idle rpm in neutral be adjusted down without affecting the idle speed in gear? Can they be adjusted separately? The book indicates that neutral should be 700-800 and in gear idle at 600-700. Also, i tested it yesterday on the water (lake temp mid/upper 50's) and ran it for 15-20 minutes ... would the colder water temps keep the idle up? If I adjust down in cold weather will it be too low in warm weather/warm water?<br />PART 2<br />My motor is equiped with a four blade prop and it has great power out of the hole and will spin the maximum recommended 5500 rpm's ... is this bad and should i add more pitch to get more top end speed and work the motor at lower rpms?<br /><br />Thanks for all feedback
