Re: Idle setting 5.7
You're just going to have to start troubleshooting. <br />Vacuum gauge tests on engine vacuum, compression tests, fuel pump pressure test and vacuum tests on the system from tank to fuel pump, ignition timing and advance tests, carb adjustments, check plug wires, tuneup...... etc.<br />You are just going to have to eliminate things systematically till you locate the problem.
