I got my 1957 Evinrude 35 hp motor #25028-12064 running today I have 120 psi compression on both cylinders new coils, points, condensers wires and plugs. Carb was rebuilt and new fuel filter . Is started right up after a few tries run it awhile in a barrel and noticed that the water pump not pumping shut it off took the lower unit off and have a bad impeller with is now on order. I noticed the water tube and I took a small hose and clamped it to it then to my garden hose. I run very well but need to fine tune the carb, I tried to get it to idle down a little lower but could not the slow idle speed needle works ok but its just doesn't idle to low is there a idle screw on this motor. It's has a control box which is not hooked up at this time I have been using my hand on the thottle lever on side of the motor where the cable connects too. Please help me .
