I am having a fuel problem which I feel could be the idle set too low. The motor is ideling in "N" about 700 to 800 rpm's. When you put it in gear it drops to 500 to 600 rpms. When you put it in gear it bucks and kicks and will cut off unless you go ahead and get it some gas If you let it sit there and idle out of gear it will eventually cut off.
Is it possible that the idle is set to low and when it idles it just doesn't get the fuel that it needs and that causes it to cut off?
The fuel pump has just been replaced, carbs were done about 3 seasons ago. Other than this issue, the motor runs great! Thanks for the help!
