Idle Stabilizer or High Speed Low Speed Spark Advance Module HELP
raganjones
Friends,
After some trouble shooting, I am so thankful to all of you for your suggestions. I thought I had a Power Pack/Switch Box problem, which I was wrong. After spending time with a friend who knew what he was doing, we found that the wiring from the switch box to the Idle Stablizer or High Speed Low Speed Spark Advance Module is corroded for about 3 inches.
I am all over the I-Boats site looking for this part, but I cannot find it by the Seloc guide name "Idle Stablizer or High Speed Low Speed Spark Advance Module."
Any help?
Thanks guys!
RJ
Faztbullet
Re: Idle Stabilizer or High Speed Low Speed Spark Advance Module HELP
Just disconnect it and trash it. Set cranking timing at 21? and will give you 19? at WOT......That is a OEM part and the number is 87076A10 and about $200
raganjones
Thanks Fatzbullet, you are a machine!
What is the part officially called in the OEM guide?
RJ
