I had some questions about setting my idle on my 140 (see http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=24;t=011752#000003). Things are better but not perfect yet! Here's where I stand so far: dwell set to 30, idle on water is 600 (off water about 750), timing @ 6. The idle screws are giving me fits. If I turn them in the idle will go up, if I turn them out the idle will eventually go down. The book says that when I turn the screw in the idle should eventually drop, not increase!<br /><br />I tried connecting a vacuum guage to the line that goes to the choke but I got no vacuum there (should there be?). If I connect the guage to the choke inlet itself, the guage shows 2.<br /><br />What am I missing here?<br /><br />Also, I could not get much above 3200 rpm, pushing a 21 prop. The boat is a '74 16ft tri-hull. Not sure if that's related or not.
