emoney
- Joined
- Jul 19, 2010
- 2,551
Chrysler 50hp (507H3D), both coils are super hot to touch, even after
sitting for couple of hours? I saw an older thread that talked about this
on a Force, where the suggestion was to check the wiring to the switch?
First, if it's wired wrong, is that going to cause the coils to stay hot?
If so, I'm assuming the wiring is sending power to the coil at all time like
it's trying to constantly "start", right?
Could this problem be at the ignition switch itself, or is it something
that is in the main wiring harness on the side of the motor? Finally,
if the switch is aftermarket, is there a specific spot for all of the wires to
go, and if so, is this something that should be on a schematic from the
switch manufacturer?
