if it aint broke, dont fix it?
Status
Not open for further replies.
btruong
Hey guys, ive ran into a dilemma with my 94 Suzuki DT40. so i was browsing through the shop manual and found the section with the info about the oil pump linkage adjustment. checked it out on my motor, and the alignment was way off. supposedly, at idle, the mark on the pump lever is supposed to line up with another mark on the pump body. note, the engine ran perfectly fine like this, but being me, i wanted to correct it. so i went about adjusting it till the idle allowed it to line up. the problem is, it cant reach WOT (the butterfly reaching horizontal) because the oil pump's stop limits the throttle arm. i reverted it back to how it was (messed up alignment). is this an error in the assembly of the fuel pump? should i worry about it if its running ok?
btruong
Re: if it aint broke, dont fix it?
im sorry, but in the first question, i meant oil pump. sorry if this caused any confusion.
bill j
What did you do to correct the issue? I have the same problem.
GA_Boater
He's not tellin' because the OP hasn't been here since August 2010 - 7 years ago.
Read the Help Tip on top of the page and start a new thread.
Closed.
Status
