ign switch wiring
rsharer
chysler 35 1971 magnito elct start<br /><br /> i've got most wiring hooked up.whats left is the white and blue wires.i know one is for tach(white).i have an aftermarket switch.it has battery,start,choke,ignition,then 2 left over.i guess would be they are for m's.with the switch off they have continutiy between them.i know if i ground out the blue wire it kills the motor.so would grounding the blue wire to the white wire kill the motor.i would think that one of them has to go to ground for kill.if i should only hook one wire to the m terminal should the other just go tach.<br /><br /> wiring diagrams show both stator leads going to m terminals on the switch.but i'm not sure if they should ground to each other for kill or to ground.
