sludgemonkey
- Joined
- May 9, 2006
- 10
My rebuild 150 Johnson is causing me great frustration.<br />Here is the story:<br />- 90psi compression on all cylinders (+/- 4)<br />- spark on all plugs<br />- New Powerpack<br />- Spark plugs appear brownish and dry on one side, and brownish but slightly wet on the other side.<br />- No change in rpm when spraying WD40 into the intake.<br />- No change in rpm when pulling one spark cable (anyone).<br />- Runs OK on idle.(sometimes misfires)<br />- Loose power and stall aout around 3000rpm in Forward.<br />I suspect incorrect ignition (linkage) adjustment being the problem.<br />Question 1. If WOT timing is too high will that cause stall at WOT.<br />Questiion 2.If carburator valve start opening prior to 7° BTDC, will that cause stalling<br />If WOT timing is set too high, wil 3% 2stroke oil<br />allow it to run smoother compared to 2%?<br />Question 3. I tried the method of Cranking with no plugs installed to set WOT timing, but i could not get it below 30° even with the adjustment screw fully screwed in.
