Re: ignition amplifier 3.8L 1984 mercruiser
The 3.8 was in a 84 malibou 80000k it had a electroinc distributor running it.
What is the reason we have to revert back to pionts and coil ignition?
Definately need some input here on this.
Tks for reply
1. the car HEI is not rated per SAE J1171 .... External Ignition Protection of Marine Electrical Devices.
It'll run, but there's a slight risk of explosion.... and scrutiny from coast guard, insurance etc..
2. that Malibu HEI is advanced for the characteristics of the 110HP smog motor, not the 170/185HP boat motor. I'm not sure how it would suit the power curve with the boat cam... might be fine. or might rob some power
with point 2, you do not want that motor in a boat without changing the cam to the one from the original motor...or for new, Edelbrock EDL2112 is the same as the marine grind.
the smog control was all in the cam and the price was about 50HP
I don't think there's any ignition amplifier on your setup. Sounds like you might be looking at the shift interrupt system.
If you have the original distributor you would probably be better off using it.
Can go to the adults only sticky and download the manual.
