Ignition and distributor help
Hildebrand
Hi, I am new to boat and need some help. Boat, 1989 sunbird with a v6 mercrusier. This is my brothers boat and he got into to far over his head and I'm trying to help him. His was having prob elms with the coil and took it apart and now doesn't know where anything goes so I'm here trying to help him out. He wanted to replace the coil,and disturbutor. So basically I have a boat with a bunch of wires and I don't know where they go. Here are few pictures to kinda see what I'm dealing with. Any help would be much appreciated
Ayuh,..... Welcome Aboard,..... I'm gonna move this to the Merc I/O forum for better answers,...
Have ya got a serial number for the motor,..??
I'm guessin' it's got an Alpha drive,..??
Do you still have the original parts,..??
probably nothin' wrong with the distributor, or the coil,...
Take a couple pictures further back, to see how much is left, 'n how much is gone,...
In my signature, click on Don'S Adults Only section,....
Then follow the links to the Merc factory shop manuals,....
All the wirin' diagrams are in 'em,.....
Providing what Bondo mentioned will help all of us help you. Here is the color codes for mercruiser wiring
Bt Doctur
do you know how to install a dist? the purple and grey from the harness and the ign module. both purples to the + and both greys to the -
Hildebrand
Thanks for the fast replies. I will try and get a far back picture here shorty. Once I figure out the wriring mess I am just gonna replace the parts for him.
Hildebrand
Ayuh,.... Do ya still have the parts,..??
Hildebrand
Trying to post picture as I type. The disty is there, but it looks like crap. So does the coil. I would like to get all new parts and wire it back up right for him
Hildebrand
I know how to install it ,but I have no clue where these wires go. I got the boat a mess and I'm trying to help him out
Bt Doctur
the amplifier/ign module should have 4 wires coming out of it purple and grey go to the coil, the other 2 go to the dist White w red stripe and white w green stripe
Ayuh,..... The distributor alone can be several hundred dollars,.....
It'll probably clean up, 'n run just fine,.....
Hildebrand
Thank you. Later today I'm going to run and just get/order a new coil ,cap,and rotor. I'll post back once I get parts and start to wire as in sure I'll ha more questions. Since he pulled the disty out, I'm guessing I'll have to retime it ? Thanks agin for the replies so far
NHGuy
Yes you will have to retime it. If he didn't mark it just go to Mercruiser manual where it give distributor install with "engine disturbed". It's their way of telling you how to find the spot.
I would not spend for a coil unless it's bad. They don't often fail.
BTW The rotor is supposed to be locktited to the distributor shaft.
Hildebrand
Sorry for the delay on responding. I had some stuff come up I had to take care of. Can I have that coil tested ? If not I'm gonna source parts this week as he wants to get the boat out to fish. Thanks agin everybody
