Ignition Coil issues
Eubie
I have an '87 Mercruiser 4.3L 175hp. I noticed yesterday when I was testing the engine before taking it out that when I start it up and rev the engine in neutral I hear sparks arching. Sounded like, tick tick tick tick tick tick. I looked back at the engine and noticed that there was a spark arching from under the center coil rubber boot to one of the terminals right next to it. <br /><br />This only happens when I rev the engine in neutral but when I rev it up in gear it doesn't do it. Why would it do this only in neutral. I understand that it shouldn't do it at all. The rubber boot of the center plug wire is pretty loose on the top of the ignition coil. Could this problem be resolved with a new center wire with a tighter fit or is there something else wrong? <br /><br />Any help would be greatly appreciated.
bluewater19
Re: Ignition Coil issues
Spark takes the path of least resistance.Try a new coil wire.
Darian F.
A coil wire would help, but you should look a little further. <br /><br />If it's been a while since the last tune up<br />by all means do a tune up, spark plugs, plug wires,distributor cap, and rotor button.<br /><br />the spark seeks the easiest path which happened to be the negative post on the coil
rodbolt
yep<br /> me, bass and lectricity. bout the laziest things on earth:)<br /> time for a coil. use some dielctric grease on the tower and boot.<br /> good luck and keep posting
Eubie
Excellent, thanks guys. I'll do the tune-up with new wires, etc.
