ignition coil resitance
bigpoppakdog
on my ignition coil which has primary lead from terminal 5/blue wire pulse pack and high tension lead to distributor. When I do a resistance test on a x1k meter these are the two readings I get.
primary lead from terminal 5/blue wire pulse pack I get 2.5 ohms(x1k meter)
secondary or high tension lead going to distributor get zero resistance.
Does this indicate a shorted ignition coil?
