Ignition Coil Test
sybaris2
Last year my tech replaced the original coil (8M0054588) with a cheap one and it fixed the issue. Engine is giving the same symptoms as last year. I have a multimeter and measured the pins in the top connector across ground. From right to left I got 1.8/S/6/3 ohms but I don't have a reference for what those pins or any others are supposed to be. Any help much appreciated.
dubs283
Post the engine serial number/model and if possible model year. Some folks here have really good access to oem mercury info/manuals and may have the specs you need
