Re: Ignition Coil
Black soot usually is telling you it's overfueling. If carbed, check the choke operation and setting. There are free manuals at the top of the forum. Check to see of your is available. Then start looking at the carb. I'm with you though, make sure the ignition is up to snuff before tearing into the fuel system. Seen it many times, carb wasn;t the issue. If the boat is new to you, start with a complete tuneup. Plugs/wires/cap/rotor, fuel and water seperating filter if you have one. It's a 93, who knows how old the stuff is...
