Re: Ignition diagram for late 80's 28 spl
Thanks for the quick response. I typed in "Evinrude 28 spl" in the search engines category and came up with nothing.
I have most of the ignition wiring completed (had to shorten the harness and resolder ring terminals in) just looking to see if i can hook my horn up in to the harness (I'm thinking it was when I bought it) or of I need to run it to my accessory battery. Also there is a brown wire that I'm not sure where it goes. My kill switch has a negative female disconnect running to the harness and ignition but no positive, only a female disconnect with the reminants of a wire crimped onto it.
In short: I need to find where to run my horn to, where the brown wire goes, and where to run a positive wire to from the kill switch.
Thanks,
Jake
